2 Piece axle nut question
Brads8N
07-13-2001 13:32:01
when you take a 2 piece axle nut off do you take them off together, or the outside part off first then the inside one last?
Dell (WA)
07-13-2001 22:09:00
 Re: 2 Piece axle nut question in reply to Brads8N, 07-13-2001 13:32:01
Brad..... .the 2 piece rear axle nut has the outer nut clamping down on the tapered thread inner nut. If'n you can take 'em both off at the same time, you ain't hogged down hard 'nuff on the outer nut. Therefore, to remove the inner nut, you must at very least, loosen the outer nut, and ya might as well remove the outer nut all the way first ennyways..... ...Dell
