Order Ford 8N Parts Online
8N not starting
Scott McCrea
07-07-2001 20:05:09
Last year I discovered a 1951 8N in my barn. I got it out,put a new battery in it and she started right up. After I drove it for an hour or so I was putting it away when she stalled and hasn't run since. I put fresh gas in it,cleaned the carb. 3 times, put new wires and plugs in, cleaned the points and still not starting. I do get a spark at the plugs. Can anyone offer any suggestions. Thanks much.
popo
07-08-2001 19:09:34
 Re: 8N not starting in reply to Scott McCrea, 07-07-2001 20:05:09
If it stalled all of a sudden and you are still getting a spark I would suspect a gas problem. As in its not getting any. If it is a spark problem it seems to me that the tractor would have been cutting out and acting up minutes or at least moments prior to the stall. If the points or the timing slipped it should have at least started sputtering or backfiring shortly before it finally died. What type of fire is it nice hot blue or yellowish and weak? I would rule out a coil due to the fact that if there is fire there and it wont hit at all unless the fire is just too weak. Check to see if there is gas in the bowl by loosening the screw or plug in the bottom of the carb bowl. If there is not, then there is a stoppage somewhere between the carb and the tank. If there is then take the carb off and with the bowl full of fuel and the carb level the way it sits on the tractor, try and blow through the fitting where the fuel line connects. If you can then the fuel can make it through as well. If you cant then either there is something stopping up the passage or the float is not "floating" properly. What did the walls of the carb bowl look like when you had it apart? were they rusted and pitted? If they were the float might be rubbing against the walls. Did you blow out all of the passages in the carb when you had it apart? Is there gas running from the front where the air breather connects. Take off the hose and check. popo
Scott
07-09-2001 10:11:31
 Re: Re: 8N not starting in reply to popo, 07-08-2001 19:09:34
The flame seems to appear yellowish and weak. The coil also gets hot when trying to start it(It has a 6 volt battery). There is also gas comming out of the front where the air breather connects as it is cranking. When I shoot starting fluid in there the only reaction is one backfire from the carb.
bg
07-07-2001 22:18:33
Assumption #1: The engine is correctly timed and plugs and points are healthy and correctly gapped.
You say you cleaned the carb. Did you take it apart and thoroughly clean all the passages with solvent and compressed air? There are a couple of small places where gasoline likes to varnish up and clog. Did you remove the plug on the bottom of the carb and check the fuel flow? You should get a fairly healthy stream, not a dribble.(I'll forgo Dell's usual urological allusions.) Did you also check the manifold to see if any little critters may have built a nest in there? If you are getting spark, shoot a very small amount of starting fluid in there and see if it fires off. If it runs on starting fluid but then dies, you have a fuel problem.
Ed-illinois
07-07-2001 20:28:12
Question One - Who "discovers" an 8N in their barn?
It sounds like the coil or the ignition switch is bad. If after cooling down the engine starts and runs again for an hour or so and stalls, it is more than likely a bad coil. However, if you get it started again and it stalls, place a wire "jumper" around the ignition switch and see if it starts. If so it is a bad ignition switch.
Those are two things to try. Of course the fuel system has several screens that could be plugged. You could also take a multi-meter to the various wires and make sure volts are getting to the coil.
