Order Ford 8N Parts Online
Locked up transmission 8n
Lance Tyler
07-05-2001 12:33:16
I have a 1948 8N. On shifting from reverse to 2nd it felt like it started into one gear without completely shifting out of the other - result is its locked up. Didn't feel like anything broke. I took off the transmission top plate and attempted to move the right side shift fork and/or top shift fork and neither will move, left side moves ok. I have heard of this and have heard its usually possible to unstick it without disassembly. Suggestions?
rod
07-05-2001 14:18:51
 Re: locked up transmission 8n in reply to Lance Tyler, 07-05-2001 12:33:16
try jacking rear end clear and get someone to rock the wheels at least take any pressure off. You should be able to move the rail with a long flat screw driver. On my TEA 20 the shift fork broke right off and flopped over inside the case. regards
rod
