Order Ford 9N Parts Online
2n and9n dash panel, can i swap?
Greg
07-04-2001 22:14:34
Will a 2n dash panel fit on a 1940 9n? I gave 50.00 for the back half of a 2n tractor, i really needed the rim's but the dash would be nice . if it fit's . Thanks
Mikey
07-04-2001 23:33:16
 Re: 2n and9n dash panel, can i swap? in reply to Greg, 07-04-2001 22:14:34
Greg,
I agree with 9N'r about the aluminum dash, I've got the same thing.
If you don't want to tear her down to find out, how about tracing the left and right sides onto cardboard, cut it out, and mark the bolt holes with a pencil?
Might save you a gasket.
Mikey
9N'er
07-04-2001 22:47:10
If both dashes are the one piece cast type with attached battery holder/platform you're good to go...assuming that this entire assembly bolts to the transmission cover.
Greg
07-05-2001 23:02:30
 Re: Re: 2n and9n dash panel, can i swap? in reply to 9N'er, 07-04-2001 22:47:10
9ner, the dash has part of it riveted to the bottom piece.( the face of the dash i mean), but the whole assembly does bolt to the transmission.
It also has a battery tray /holder on the front of it.
