2N Front Wheel Stud Replacement
Ed-illinois
07-04-2001 21:18:40
Had a front tire go flat on my 2N today. I hit all the bolts with WD-40 and went back to the barbecue for an hour. Came back and the nuts on the right wheel all turned fine. On the left wheel, I had to use a helper pipe on all the nuts and ended shearing one of the bolts off! After that we had to take a sledge hammer to the wheel to break the rust seal with the hub.
Question, how do I replace the stud bolt? I see that it looks like a carriage bolt with a small portion of the head chopped off to lock it in place.
DavidZ
07-05-2001 04:13:27
 Re: 2N Front Wheel Stud Replacement in reply to Ed-illinois, 07-04-2001 21:18:40
Yep, those front studs are impossible to find. You can get real nice one while at Ford New Holland; just ask for Ford 2000 studs. There the same size and shape with the funny little heads. They are maybe 1/4 to 1/2 in longer than the original. One thing, watch out for the back studs. They are available but around 12$ apeice.
Mikey
07-04-2001 22:37:35
ED,
Had the same problem w/ my '41. Heated the stud and the area around it with a torch and let it cool. Drove it out with a hammer and a punch.
I tried to find a stud (with or without the flat) at the local parts stores. No luck. Got one from Don @ just 8N's.
As far as I could tell, the stud was pressed in. I had to use a press to install my new one. With a little grinding you might get it in with a hammer.
My nickels worth!
Mikey
Popster (MD)
07-04-2001 22:17:22
FWIW, in my experience, WD40 is good for displacing moisture and as the ultimate male cologne. It really not a lubricant. Had a neighbor grind the gears off his boatlift using that stuff.
There is a product called Kroil, and they make a Silikroil that has been working wonders on frozen bolts, nuts, motors, etc. for me for over 25 years. Do a search and check out their web site. I'm not connected in any way; it's just good stuff.
roperboy
07-04-2001 21:37:03
you got it right ed. just take a grinder to the head of a carriage bolt.
