3 Point Scoop improvement
Steve Warfle
03-27-2000 06:16:49
I bought a new 3 point hitch scoop from Central Tractor last week. Against everybodies advise, the one I bought is a Howse, with a latch on the frame. But I thought of a cheap way to fix it, and I already have installed and used this invention, and it works great. So here it is.
The problem with a frame mounted latch is that if the load is in the back of the scoop, it won't tip. Or if there is too much of a load, the trip gizmo has too much pressure, and is "Stuck".
To fix this, I mounted a double pulley on the frame, directly over the latch. Then I mounted a single pulley on the latch. The trip rope runs from a tie off point next to the tractor seat. Then through the double pulley, down to the latch single pulley, back up through the double pulley, and then it goes down, and is tied off to the back of the bucket.
So now, when I pull the rope, it pulls the bucket and the latch at the same time. This fixes the stuck latch problem, and the mechanical advantage tipping the bucket isn't bad either.
It's a bummer to have to resort to fixing a design flaw on a brand new piece of equipment, but this fix works great. Not a genious as a "Zane Thang", but I hope I help one person. I feel I owe this board a lot.
Good Luck, Steve
dave#1
03-27-2000 18:29:54
 Re: 3 Point Scoop improvement in reply to Steve Warfle, 03-27-2000 06:16:49
Well that's simple enough !
Lot easier than what I had to do to my C.T. scoop, I got so pi$$ed off that I cut the latch off and reworked it and welded it on the scoop instead of the frame, now it's like a new scoop !
later,dave
Hendo (OR)
03-27-2000 07:27:51
I've had it with Central Tractor, I had an order in for several items and not one was worth the trouble. they call themselves Quality Farm & Home or some such thing.
One of the items I ordered was a set of top stay bars for the 3Pt. what I call stationary bars.
When they came I put them together but, when I tried to mount them on the tractor the top ends wouldnot fit in the pin yoke so now I either send them back or get out the grinder. The fancy radiator cap I got fits on sideways, all this stuff is made in China, I am going to have to get my stuff from New Holland but maybe it will still be from China?
Last year I ordered a rain cap for a new verticle exhaust pipe on my JD 950, they had to send it to me 3 times before they got the correct one, at least I did not have to send the other 2 back because the price was as much as the UPS charges.
I have been a customer of Ct for 25 years and have poured a lot of money in there pocket through equipment and parts for 3 9Ns and a couple of JDs, they are not the same company. I am disapointed.
Hendo (OR)
03-27-2000 07:27:31
Dave 50 8N
03-27-2000 07:16:02
Steve,
I just bought a Howse scoop a month or so back and am interested in your pulley fix. Can you post a picture of your fix? thanx!
