Order Ford 8N Parts Online
8N clutch cross shaft removal
boda
07-04-2001 16:49:38
Hi all, We are installing a Sherman Combo tranny in my dads' 51 8N. The clutch cross shaft needs to come out in order to do so. The trouble is, the cast iron fork that pushes on the throwout bearing is pinned to the cross shaft and I can't seem to get it out. Is this a tapered pin? Do I need to drill it out? It looks like one end is bigger than the other, but I whacked it pretty good with a BFH and it wouldn't budge. Any advice appreciated. I couldn't find an answer in the archives or in the trusty FO 4. Thanks, boda
JD
07-05-2001 08:11:19
 Re: 8N clutch cross shaft removal in reply to boda, 07-04-2001 16:49:38
The pin is mushroomed on the back side like a rivet. You'll need to grind that off before the pin will come out. Looking from the front of the tractor at the fork pointing up is the head of the pin and it will come out toward you.
