Order Ford 8N Parts Online
52' 8N Ford No Fire
Walnut Hill
03-26-2000 18:36:12
I still can't get any fire out of the 52'ford 8n I have replaced all the Plugs,point and cond. wires,coil,and checked all the wires from the switch back but I am now going to pull hood and check wires on the regulator back and I will guess replace it too one or the other it will go I hope any advice ..... note this tractor was running go then all of sudden quit... so I am just starting at points and coil and working my way to the problem....Help ???
Fletch_NC
03-27-2000 05:07:53
 Re: 52' 8N Ford No Fire in reply to Walnut Hill , 03-26-2000 18:36:12
I just went through the same thing. 8n (sidemount) running perfect for 2 years. All of a sudden no start. Checked plugs- no spark. Replaced coil and condensor-no spark. Did have spark from coil to ground with wire from coil to dist cap unplugged. replaced distributor cap and rotor- runs perfect again. cap and rotor looked good.
There are lots of things that. could be wrong, just take it in sequence.
Good luck....8n303882
bg
03-27-2000 04:32:43
Besides jumpering around the ignition switch, have you checked the stud on the side of the distributor where the small wire attaches? The insulator often fails, grounding out on the distributor body. A VOM and test light come in handy here.
Charlie in TX
03-26-2000 20:39:54
Try jumpering out the ignition switch.
