Jubilee question
jim
06-29-2001 20:18:14
i have a chance to buy a jubilee. my question is are the parts available like they are for the 9n and 8n .also how much horsepower does it have over the 9n and 8n
Patrick/N-Tiques/OR
06-29-2001 23:44:19
 Re: jubilee question in reply to jim, 06-29-2001 20:18:14
Jim,
The Jubilee is about 8 or so horse power stronger than an 8N and over 10 more than a 9N. It has a live hydraulic which means you do not need the PTO on to use the 3 pt. lift.
Most parts are still available as they are kind of a cross between an 8N and a 600 series. "Cross" is not exactly the right term... more like in between.
Anyway, I have both... actually two 8Ns an two Jubilees. I use the Jubilee for the heavy work... you can feel the difference in the power.
If I had to make a choice (I did... I got both!)... I would go with the Jubilee.
Check out the web site I listed below... it has a lot of good data.
Best of luck!
Patrick
michael-ga
06-29-2001 20:55:02
Parts are readily available I would estimate as much an for an N. It has a few more horses, but not sure how much more. Great tractor, you will not be disappointed.(if you check it out good)
