Jubilee-positive or negative ground? THANKS!
michael-ga
06-27-2001 20:58:09
x
bg
06-27-2001 23:20:05
 Re: jubilee-positive or negative ground? THANKS! in reply to michael-ga, 06-27-2001 20:58:09
Doesn't matter to the tractor, unless you converted to 12 volt alternator which has to be negative. The Jub was positive ground. Just make sure to polarize your generator(if that's what you have). Assuming everything is wired correctly and in good shape, with engine dead and ignition off, connect a jumper wire from the BAT terminal of the regulator and brush it against the ARM terminal for a millisecond.
