Locking tranny
Mike H(MD)
06-25-2001 17:40:55
Anyone have any ideas on what to look at first? My trans locked up when I went to do some bushhogging. First I thought it was the mower but was still locked after it was disconnected. Once pto was disengaged could drive with no problem. tried pto again it would turn but was lugging the engine bad. should I look at pto side or inside the tranny first?
Mike
I assume . . . Dell (WA)
06-25-2001 22:38:29
 Re: locking tranny in reply to Mike H(MD) , 06-25-2001 17:40:55
you did the obvious..... check to see if'n the brushog blades are not jambed up with cuttings..... .Dell
mike H(MD)
06-26-2001 03:38:39
 Re: Re: locking tranny in reply to I assume . . . Dell (WA), 06-25-2001 22:38:29
blades aren't jammed with cuttings, ORC is in use.It was doing same with mower disconnected from tractor
then I'm afraid . . . Dell (WA)
06-26-2001 15:22:04
 Re: Re: Re: locking tranny in reply to mike H(MD), 06-26-2001 03:38:39
there is only one cure...a tranny-lumpta-metric.
Unfortunately, A tractor split and tranny rebuild is probably in your future. Its been done many times by the unexperienced, including ol'horsefarmers whose idea of repair is bailing wire and a bigger hammer..... ..Dell (grin)
Mikey
06-25-2001 20:39:54
Mike,
You mention that everything is fine without the mower hooked up. Do you use a ORC? could you have hit something with the mower and bent the PTO shaft? Does the PTO shaft turn freely without the mower attached? Does the PTO have a wobble to it?
If worse comes to worse, drop the front of the tractor in a ditch and pull the PTO. Four bolts, piece of cake. Lets hope it isn't bent.
Eliminate everything it isn't, and whatever is left is the cause!
Mikey
Mike H(MD)
06-26-2001 03:44:21
 Re: Re: locking tranny in reply to Mikey, 06-25-2001 20:39:54
PTO shaft doesn't appear to have a wobble to it. It felt like it was free when I turned it with pto disengaged but was jerky when turned by the engine which is why I was wondering if it was the coupling for the pto or the transmission
Mike
