Order Ford 8N Parts Online
8N Cooling System Problems
Dan Feezor
06-23-2001 18:13:10
The last 2 evenings, mowing, my 8N (1948) overheated. I was mowing wet grass, and it was pulling harder than normal, but not excessive.In addition, it was a very cool evening (55 degrees). I have a 12 volt conversion, and the alternator pulley appears to be a rigged system. It appears that I need to tighten my fanbelt, but I can't since my alternator is all the way out. When I filled the antifreeze today, and watched down the radiator when the engine was running, I saw no obvoius signs of flow. Could someone describe what this flow should look like, if the water pump is functioning properly? Is it a swirling motion, or is it very subtle? My proposed plan of attack will go in the following steps.
1) Clean radiator (only 2 years old), 2)get smaller fan belt for tighter tension, 3)if no further sign of flow, replace water pump. Please note that I do not have a thermostat. Do these steps seem reasonable, or should I be checking something else?
Thanks,
Dan Feezor
raytasch
06-23-2001 18:59:33
 Re: 8N Cooling System Problems in reply to Dan Feezor, 06-23-2001 18:13:10
Should see noticable turbulance in the coolant. If the belt is loose replace it as first step. Make sure air flow through the radiator is good; fins clean. How about timing and advance? ray
