Order Ford 9N Parts Online
9N timing
Bill Schirmer
06-20-2001 15:24:20
I live at an altitude of 7000ft. and am having trouble timing my 9N. Is the advance plate on the distributor capable of advancing the timing far enough for this altitude? Any help with the timing would be welcome.
Dell (WA)
06-20-2001 16:00:47
 Re: 9N timing in reply to Bill Schirmer, 06-20-2001 15:24:20
Bill..... ..Carb mixture too rich is usually the problem with altitude, not ignition timing.
Yeah, innna the olden times of low octaine gasoline, timing could be critical at very high altitude but usually its the carbs that couldn't be leaned enuff. I grew up in 6250 ft Durango, Colo, so know a little bit about the effects of high altitude.
I would suggest that you might be having centrifical advance wear problems with your front mount distributor..... ...Dell
