Transmission Differential fluids
Jerry Everett
06-20-2001 05:18:18
My 8N Ford Tractor manual lists the fluid capacity
of the Transmission, Differential and Hydraulic Systems as 20 quarts and I assume from this that this is all one interconnected system. Is this true and what fluid and weight should be used? Any tips or quirks about changing fluids?
Thanks.
bj/8N/mt
06-20-2001 05:38:14
 Re: Transmission Differential fluids in reply to Jerry Everett, 06-20-2001 05:18:18
Not quite a million posts yet on this question but you put it close. Yes the manual is right--five gallons three plugs. Start with the little pipe plug and work up the the big ones. Check the archives of this board for all you would ever care to know about whether Ford spec 134 or 90 wt is the way to go. With either:
Your mileage may vary
