Order Ford 8N Parts Online
8N Plugs
Ken/Wa
06-18-2001 21:36:24
Recently purchased a tune-up kit for my 1951 12 volt side mount dist. I got autolite 437 plugs. It seems to run better with the old champion H10C plugs. Are the autolite plugs the same? They look a little different.
Dell (WA)
06-18-2001 23:55:39
 Re: 8N Plugs in reply to Ken/Wa, 06-18-2001 21:36:24
Ken..... .Autolite 437's are the recommended replacement for Champion H-12's (kinda) The H-12 is a hotter plug than H-10 original equipment. Most N-Tractors need the hotter plug to prevent fouling from oil burning.
If'n you were plowing 12hrs straight in 100 degs with half gas and half panther pi$$ like 50 yr old gas used to be, then you'd probably need H-10s. But most N's arn't worked that hard any more so hotter H-12's or Autolites 437 are a better choice.
BTW.....make certain your new sparkplugs are gapped at 0.025. Most sparkplugs need gapping right out of the box..... ...Dell
Ken/Wa
06-19-2001 07:48:21
 Re: Re: 8N Plugs in reply to Dell (WA), 06-18-2001 23:55:39
Thanks for the info. I just got to thinking, I ordered original wires and I bought the tractor converted to 12 volt. Maybe I have the wrong wires now. Any rate, it ran better with the old stuff in it. I gapped the plugs between .025 and.028, but will make sure they are at .025.
Mountainman
06-19-2001 12:14:21
 Re: Re: Re: 8N Plugs in reply to Ken/Wa, 06-19-2001 07:48:21
You should be fine with a gap between .025 & .028 (more important that they are all the same gap) but do make sure you are using solid core plug wires, not the more common carbon core.
You might want to check the archives for more info on checking the voltage at the coil to be sure the 12 volt conversion was done right.
Hope this helps.
Mountainman (CA)
Ken/Wa
06-19-2001 12:52:09
 Re: Re: Re: Re: 8N Plugs in reply to Mountainman , 06-19-2001 12:14:21
Thanks for the advice. It has not run well since I bought it , so I will check the archives for the proper way to convert.
