Order Ford 8N Parts Online
Jump.g start 8N
Fred
06-17-2001 09:58:01
Will I end up with a burnt out system if I "jump my 6 volt 8N with my 12volt pickup? thanks in advance.....Fred
Steveo
06-18-2001 07:17:01
 Re: Jump.g start 8N in reply to Fred, 06-17-2001 09:58:01
I've done it a few times with no negative consequences. Just connect pos to pos and neg to neg between the batteries, and disconnect it soon as she starts.
ZANE
06-17-2001 10:11:15
When jump starting an N tractor with 12 volts it not necessary to hook the 12 volts to the 6 volts battery at all. As a matter of fact I strongly reccomend against it.
Instead hook the 12 volts directly to the frame of the tractor for the ground and with the transmission in neutral and out of the way of the wheels of the tractor so you don't get run over touch the other cable from the 12 volt source to the post on the starter.
By doing it this way you don't even have to worry about the polarity of the batterys or which cable you have to ground or positive to the frame or the starter as the 6 volt systme is not intered into at all with the 12 volts. Just turn on the switch and touch the hot cable to the starter post and it will go.
