Order Ford 8N Parts Online
2N rad on 8n tractor ? Thermostat?
DRC
06-17-2001 07:00:11
Looks ike i have a 2n rad on my 8n? Has a 2N marking on the side. Also has a tiny 1/8" hole in the neck of the top pipe( where the rad cap goes).
So I assume this is a "umpressurized" rad? Or should i fill the tine hole with JB Weld and continue on? Any pros /cons to pressureized vs unpressurized? Anybody run without a thermostat?
Chris(MI)
06-17-2001 15:06:11
 Re: 2N rad on 8n tractor ? Thermostat? in reply to DRC, 06-17-2001 07:00:11
Small hole is where the overflow tube should be brazed on.
Tyler (MD)
06-17-2001 09:56:57
It should be pressurized. The pressurized radiator came with 2N model in '42.
Tyman
Claus
06-17-2001 09:45:53
The cooling system is designed to operate with a cap that relieves pressure between 3.75 and 4.25 lbs psi. This will allow the coolant to reach 212 degrees without boiling. When I lived in Florida, I never ran with thermostats. If you live in cold climates (especially in Alberta) it would behoove you to run a thermostat. This will allow the engine to reach operating temperature quickly. You should check the thermostat in a pot of water being heated on the stove. Should open at 160/165 and be fully open at 190/200.
Happy Motoring
Claus
Dave iN Alberta
06-17-2001 08:35:31
Have run without a thermostat for years. There is one on the rad but it is so loose it does not do anything but keep me dry when doing rough work. The engine never gets hotter than it should and keeps on tickin'.
