1947 Ford
spence
06-15-2001 18:51:09
I found what I think is a 1947 Ford 2N. It says Ford Ferguson on the front grill. The only numbers I could find were on the back axle saying 4-25-47 and under that 2M4014A2. Where is the serial number? Tractor cranks but won't start. New tires, lots of rust, all parts there except exhaust. What's it worth? Thanks
TimK
06-16-2001 22:52:13
 Re: 1947 Ford in reply to spence, 06-15-2001 18:51:09
Tractor cranks but won't start, because: it's got low compression, it's got shot wiring, it's got clogged fuel line, it's got a blown timing gear, it's got a crack in the block, it's got..... ....etc. etc. See what I mean. Ain't worth much unless the owner can get it going, and if the owner can't get it going, assume the worst. $500 tops. My $.02
Paul8n
06-15-2001 19:39:28
As you sit on seat it should be on your left side of the block. A machined flat spot 1 1/2" x 3". Might be painted over so you have to doa little scrapping. Approx. in the middle.
