King pin anyone?
Doug in MN
03-21-2000 18:06:12
What are the symtoms to a bad king pin and bushing. Everything seems tight but my 52 8N did come with the shroud cut away in one spot. I'm in the process of doing some other work and have the hood and radiator off so the access is easy. Thanks..... Doug
?? Kingpin or front axle pin!
03-22-2000 08:54:37
 Re: king pin anyone? in reply to Doug in MN, 03-21-2000 18:06:12
Are we talking about the center pin in the front axle or does your tractor have kingpins.. My tractor needs a new axle pin too how hard is the replacement of this pin???
Steve (IA)
03-22-2000 09:02:35
 Re: Re: king pin anyone? in reply to ?? Kingpin or front axle pin!, 03-22-2000 08:54:37
I found my new one at CT. Should be able to get one at any place that sells N parts.
2fordsmike
03-22-2000 08:44:57
Another sign is radius rods that bend upward or are beginning to bend upward. I used to presume that these bends were caused by riding up over a a stump, log or other obstacle. I' ve learned a worm kingpin is often the cause. Mike-Iowa
bg
03-22-2000 05:01:39
If you have occasion to drive your N diagonally across a shallow ditch or other such terrain, the front axle will swivel to its maximum range. If the kingpin or bushing are worn the axle will hit the fan shroud(if it's still there), causing the fazn to hit the shroud with a horrendous clattering noise. Or if it's a front-mount distributor, it may break the cap. If neither of these things happens, the kingpin/bushing isn't that bad....yet.
Steve (CO)
03-21-2000 21:40:19
If the king pin/bushing fit is tight and there is no noticeable yaw, wobble or excessive fore and aft movement of the center axle, you're probably O.K.
