8n generator
Claus
steve(wy)
03-21-2000 13:25:05
I did the checks as you suggested and sure enough I was reading only 6.23. With the field terminal grounded I was only reading 6.4 and the generator started making a squeeking sound. I jumpered the bat and gen terminals of the VR and got a reading of 6.23. So it looks like it is time to rebuild the generator!!! Any input would be appreciated before I start tearing into this thing. Thanks for the help so far.
Ed Gooding (VA)
03-22-2000 12:32:37
 Re: 8n generator - Claus in reply to steve(wy), 03-21-2000 13:25:05
Steve, I agree with Claus about getting it done professionally. I took mine to a little, hole-in-the-wall starter/generator elec. repair shop and they rebuilt it for $35 and I had it back the next day.
fwiw..... ....Ed
1952 8N475798
Claus
03-21-2000 15:57:00
Ok...Well done... Generator rebuild kits are cheap and usually will do the job...Don't break the pulley on the generator when trying to remove it.. A bearing separator works well here. If you have an impact gun, that is the way to remove the nut on the pulley rather than butchering up the armature in a vise...Take some medium grit sand paper and use it to clean up the commutator.. Check to make sure that the mica separators are not protruding the commutator, otherwise it will destroy the new brushes quickly. Somtimes it is best to have a local generator/starter repair place do the work for you if you have one near by. They usually do not charge too much... The cost of one broken pulley ($45.00) would probably take care of it.. and they can cut the armature and undercut the mica professionally.
Happy Motoring
Claus
