U302 Diesel
Ethan
09-23-2002 12:44:16
I am building a Jet Star puller. U302 blocks work? Where do I look for the 3-7/8" diesel U302 blocks. I can't find any anywhere.
Kevin Bauza
10-04-2002 20:49:24
 Re: U302 Diesel in reply to Ethan, 09-23-2002 12:44:16
Be prepared to possibly bear the wrath of a fanatic presevationist. DO NOT USE LOW PRODUCTION TRACTORS AND PARTS FOR PULLERS -PLEASE!!!!! !!!!! GET and use something that a lot of was produced. I am a MM collector/lover/enthusiast that would just as soon waste a JD orIH for this sport than a beloved MM Just my 2 cents worth
Ethan
10-05-2002 08:34:09
 Re: Re: U302 Diesel in reply to Kevin Bauza, 10-04-2002 20:49:24
I think you are probably correct. I will probably use U302 gas blocks bored out and sleeved. Nice to know there are a few of you guys out there that appreciate that stuff.
BMG
09-23-2002 15:28:54
Ethan,
Good Luck. They only made 190 diesel U302 tractors. The parts are hard to find. Someone out there might have a set but they are going to want an arm and a leg for them. I'm not sure but you might want to look into sleeving your cylinders oversize and having custom pistons made as an alternative to finding the diesel blocks.
Brian
Ethan
09-24-2002 04:03:40
 Re: Re: U302 Diesel in reply to BMG, 09-23-2002 15:28:54
I have heard of sleeving oversize, but I am not quite sure what it takes. I have seen 5" M5 diesel blocks sleeved with some block filler. Are the old cylinders bored right out of the block? I don't know much about this technique other than it is done alot. I just bore blocks to the max of the casting. Interesting to hear what folks have done.
