Tractor ID
wcs
09-21-2002 07:59:04
I ran across a moline today that I need help identifying. When I first seen it I thought it was a jetstar 2, but after a closser look I really dont know. It dosent have a id tag on the rear end and the tag on the engine block says 220a-4 right below the starter there was a tag that has some milatary spects and 1958 I dont remember exactly what all it said. It has a wide frount and the rear wheels have the cast centers like a U but not as big a tires. But it resembles a Jetstar2 sheet metal and frountend. Is this tractor rare? Thanks Chris
JK
09-21-2002 13:00:24
 Re: tractor ID in reply to wcs, 09-21-2002 07:59:04
Sounds like you are describing a Big MO 400M but I thought they were all made in 1959. If it is a Big MO 400M, It should also have: only 4 speeds in the transmission no torque no power steering no hydraulics fixed width front axle with axle toward rear crank start at rear of tractor above PTO
John
