UTS Special?
david smith
09-13-2002 15:17:21
How can u tell the difference between a uts special and just a uts? I just bought a uts diesel and i was wondering if it was a special. Thanks
Charles Vesser
09-17-2002 15:06:24
 Re: UTS Special? in reply to david smith, 09-13-2002 15:17:21
Its real simple to tell if you have a UTS SPECIAL. If the serial number starts: 0121 it is. Any other numbers: it is not. Respectfully, Charles
BMG
09-18-2002 14:52:32
 Re: Re: UTS Special? in reply to Charles Vesser, 09-17-2002 15:06:24
That's not necessarily true. All UTS from mid 1952 and on started with "0121". Only 01214126 to 01215150 are Specials.
Brian
Charles Vesser
09-19-2002 21:15:03
 Re: Re: Re: UTS Special? in reply to BMG, 09-18-2002 14:52:32
BMG is correct.
JK
09-13-2002 17:29:38
On a Special:
The front casting has a power cylinder hole similar to a 5 Star.
The grill is flat similar to a ZA, ZB, GTB or GB
There is a piece of sheet metal wrapped around the top of the front casting to hide the power steering cylinder.
John Kinsey
Jason
09-13-2002 20:42:19
 Re: Re: UTS Special? in reply to JK, 09-13-2002 17:29:38
What is the difference between a UTS Special and a UB Special?
BMG
09-14-2002 16:37:29
 Re: Re: Re: UTS Special? in reply to Jason, 09-13-2002 20:42:19
UTS Special is a standard tractor with a non adjustable wide front end, optional power steering and still has a hand clutch. UB Special is row crop tractor as John described above with a foot clutch - same as it's UB predecessor. UTS Special has large wheatland rear fenders similar to a GB.
Brian
KX
09-16-2002 12:18:48
 Re: Re: Re: Re: UTS Special? in reply to BMG, 09-14-2002 16:37:29
I bought a 52 UTS LP that had those fenders on it, did any of that model and year come with the wide flat tops like a GB?
BMG
09-16-2002 14:54:02
 Re: Re: Re: Re: Re: UTS Special? in reply to KX, 09-16-2002 12:18:48
KX,
My parts book shows that a few very late 1955 UTS tractors had the large fenders from serial # 01213626 and later. The Specials came out in 1956 starting with serial # 01214126. It looks like maybe some late 1955 UTS diesels had the large fenders too. If yours is a 1952 it should have had the clamshell fenders. I think the big fenders really make them stand out as long as you've got a tire that will fill the fender.
Brian
KX
09-16-2002 20:36:30
 Re: Re: Re: Re: Re: Re: UTS Special? in reply to BMG, 09-16-2002 14:54:02
BMG, Thanks for the info. I did take the larger fenders off and put on clamshells. The tractor has 18.4 x 30 tires on it that did fill up the flat tops but I think it looks even better with the big tires and the clamshells. There is a pic of in the gallery under 52 UTS, Keith in TX. Took last winter (2001).
