RTU head bolt torque
Kyle Sands
09-13-2002 09:46:07
Can someone tell me the proper torque for head bolts on an RTU? Thanks,
Kyle Sands <>< Huntley, MN
Jim Parisot
09-16-2002 14:04:25
 Re: RTU head bolt torque in reply to Kyle Sands, 09-13-2002 09:46:07
Kyle,
I don't think in any of the earlier manuals on the R's and Z's they gave any specs for these, perhaps that is why no one gave you an answer. I did rummage through some stuff and in the late RTI owners manual it says to use 50-55 foot pounds for clean dry threads and 45-50 for well lubricated threads.
If you had the blocks off you are supposed to just snug the nuts down on them then tighten the head nuts then tighten down the blocks. Tighten the head down by starting in the middle of each block and alternate between each side as you work your way to the outside. I can send you a scan of diagram if you wish. Hope this helps.
Jim
Kyle Sands
09-18-2002 15:05:29
 Re: Re: RTU head bolt torque in reply to Jim Parisot, 09-16-2002 14:04:25
Thanks Jim, that's all I needed to know. I have the diagram, just didn't know what a good torque spec would be. Regards,
Kyle Sands
09-15-2002 18:21:20
Anybody able to help me out?
Kyle
