GB LP
CS
09-12-2002 19:15:08
I have a GB lp that was starting great until the other day. It wont start with the starter but I can pull it and it will start right up and runs great. I am new to LP and need to have an idea on were to look for the problem. It has a ensign carb and regulator on it. When I got it I took the regulator apart and cleaned everything up and it ran fine for about a month. Now it has quit starting. Any advice will be greatly appreaciated. Chris
scott AR
09-12-2002 19:34:27
 Re: GB LP in reply to CS, 09-12-2002 19:15:08
Chris, I bet the high pressure seat is leaking thru on that old Ensign and "flooding" the motor. Shut off the fuel and crank it until it clears, it will probably hit a little. If that's the case, find some ole boy in AR you can get an Impco from.
