Wheel Weights for a 445
Ed Haas
09-05-2002 19:03:49
I have a 1956 445 that I bought from a guy who only used it for show. I am doing some small time farming with it. He did not have any calcium in the tires and I am leaning toward wheel weights instead of calcium. Will wheel weights from any other tractors fit? If yes which ones. If no, do you have any ideas where I can find MM wheel weights in Ohio?
galen
09-08-2002 15:13:51
 Re: Wheel Weights for a 445 in reply to Ed Haas, 09-05-2002 19:03:49
If you have 38 inch rubber There is a UT518 wieght used on the U and UB. There is a 10A373 weiegght that was used on later 38 inch tires
Harrold Rhodes
09-08-2002 11:55:53
I would definitely go with weights instead of calcium. I think all of your weights from Z thru 670 and maybe more will fit the 445 universal. The 445 utility took a different weight due to smaller size in diameter of the rear wheel.
