What have i got?
jim (ky)
09-03-2002 18:45:44
I bought this MM tractor but the guy did not know anything about it. It used to be his fathers and his father is deceased, it sat in the woods 5years it has a plate on the engine with numbers-m-206 H-4 and one on the trans ser-101086 can someone please help thank you very much.-JIM
SWMolines
09-03-2002 22:07:13
 Re: what have i got? in reply to jim (ky), 09-03-2002 18:45:44
Looks like yuou have a MM 445 Universal but I think you are missing a few digits in the serial number. Hope you plan to restore it.
jim (ky)
09-04-2002 04:42:33
 Re: Re: what have i got? in reply to SWMolines, 09-03-2002 22:07:13
Thanks SWMOLINES, Can you give me any information on this tractor? What does the universal mean,what is the H.P and engine size. Where can i get parts. Thank you for your help.-Jim
SWMolines
09-04-2002 07:20:42
 Re: Re: Re: what have i got? in reply to jim (ky), 09-04-2002 04:42:33
The MM 445 was built in the late 1950s. It was rated at approx. 40 hp with a 206 CI engine. Being a universal, it should have 38" rear tires. The front end should be one of the following: 1) an adjustable wide front, 2)narrow front with two tires, or 3) single tire front. Universal means it could be configured to suit the farm's needs for working in the field.
There are a lot of people who deal in parts on this and other MM web sites. Check the list of suppliers at Minneapolis-Moline.com. You should be able to easily find the stuff you'll need to get it running again.
jim (ky)
09-04-2002 09:35:38
 Re: Re: Re: Re: what have i got? in reply to SWMolines, 09-04-2002 07:20:42
Thanks ALOT SWMOLINES YOU HAVE BEEN A BIG HELP. THANKS AGAIN,---JIM.
Chris S
09-04-2002 18:47:19
 Re: Re: Re: Re: Re: what have i got? in reply to jim (ky), 09-04-2002 09:35:38
Jim,were are you located in Ky. I live in Campbellsville. I have alot of 445 engine parts. THanks Chris
jim (ky)
09-06-2002 04:49:58
 Re: Re: Re: Re: Re: Re: what have i got? in reply to Chris S, 09-04-2002 18:47:19
Chris i live in Mayfield Ky.
Chris C
09-06-2002 06:04:49
 Re: Re: Re: Re: Re: Re: Re: what have i got? in reply to jim (ky), 09-06-2002 04:49:58
That's a great place to live! I grew up in Mayfield. You have another MM guy in Fancy Farm. Robert Elliott (GN TWD puller also). Robert would be a good resource if you run into trouble!
jim (ky)
09-06-2002 13:59:38
 Re: Re: Re: Re: Re: Re: Re: Re: what have i got? in reply to Chris C, 09-06-2002 06:04:49
Thanks for the info Chris, Just bought it last week don't know much about it have'nt had a chance to check it out but i know engine is stuck and i think it's stuck in gear. Jim.
