Soldering a gas tank
John
09-01-2002 19:06:39
What is the right way to prep a tank before soldering? I have to fix it because my gas cap wasn`t venting properly and cracked the joint at the fill hole. Any info to help me do it safely would be great. Thank You
Kevin Moschenrose
09-01-2002 21:04:17
 Re: Soldering a gas tank in reply to John, 09-01-2002 19:06:39
Instead of solder try J.B. Weld it will with stand gas, and be safe, and just as easy, and can be sanded too!
John
09-02-2002 14:23:25
 Re: Re: Soldering a gas tank in reply to Kevin Moschenrose, 09-01-2002 21:04:17
Kevin, took your advice, my leak is fixed. I also made the vent hole in the cap a little bigger. Thanks. John
