Tyler, It seems that you have gotten as much misinformation as information to your question. A cab would look neat on your 1951 RTE but it is much too late a tractor to have had it installed as original equipement. No one knows for sure how many cabs were produced, but the 401 figure is always thrown around and seems reasonable, yet unsubstantiated by factory documents. As for all being built in 1938, I really doubt it, as the first tractors were a 1939 model year. Also, if all were built that early on, then some had to be modified at two separate times as there are 3 variations of the cab. The first type fit the "square" tank, early R's. The second fit the "round" tank, starting at serial #404801 and the third fit serial #405699-up with the new narrower platform. The parts books all show a second "round" tank for tractors with cabs. As far as only being fitted to row crops, the cab was available for the standard tractor as well. MM literature shows the cab on standards and also states all options available on the row crop are available on the standards. If they were having a hard time selling cabs do you think they wouldn't drop one on a standard tractor if someone wanted it? With that said, how many standards would have been equipped with cabs - not very many I'd think? As far as the slit in the serial tag theory, I thought that was dispelled long ago. Upon close examination it becomes apparant that the tractor serial tags were stamped with the 3 5/8 x 4 engine size as per the engine serial tags and MM was too cheap to throw them out so just cut the misstamping out and put them on the tractors. As far as the mail carrier special, I seriously doubt that MM ever sold even one of them. As far as I know there are only 2 photos of the same tractor in front of the same building. And, it's not a standard type tractor, it's more of a high crop style as the wide front has much longer knees and the print literature states it has 38 inch rear rubber. The non-adjustable wide front is much lighter duty than the standard tractors. I have never seen one, heard of one, talked to anyone who has, or even heard a rumor of ones existance. I must admit, it's a really interesting concept and a neat looking tractor, looks like a "square" tank tractor in the picture. Hope this helps straighten out a few points. Jim
