UTU Live PTO
Bill Becker
08-25-2002 06:19:42
The LPTO clutch on my U began slipping to the point that I couldn't drive the tractor onto my trailer. I removed the cover on the left brake housing and found the clutch pack dripping with oil. I replaced the two oil seals in the housing and cleaned up the clutch with solvent and put it back together. It is still slipping, but not as bad as it was.
Should I have taken the clutch apart to clean it? Do I need to replace the disks?
Kelvin
08-26-2002 18:24:25
 Re: UTU Live PTO in reply to Bill Becker, 08-25-2002 06:19:42
The Lpto on our ZB started slipping and it was leaking from the seal between the inner and outer shafts. Did you replace that one?
As I recall, the clutchpack is a real bugger to reassemble. the springs are between little caps that rock back and forth on ball shaped places in the housing.
It sounds like your linings are pretty well saturated. If they are riveted on, you can cook the oil out of them. If they are bonded, you probably will have to replace the plates, or get someone to reline them.
I've cooked the clutch dry on a MM V before. I Just put it on a piece of sheetmetal on a hotplate at 400-450 degrees and let her get hot and sit until she quits smoking.
scott AR
08-25-2002 15:14:27
I'm not familiar with IPTO on a MM as all mine are not live but a Massey dealer here used to keep a bucket of "clean", sifted dust to throw in on wet clutches. They would throw about 1/4 cup in at a time with the engine running slow and someone engaging and disengaging the clutch. I'm talking about dry clutches not a wet chutch that runs in oil.
