Right rear axle seal
John from IL
08-24-2002 14:55:48
Could some describe how to change the axle seal on the right rear of a UTU? Are there any tricks or shortcuts that you have learned? Any help would be great from you Moline fellas. Thanks
Kevin Moschenrose
08-24-2002 19:11:59
 Re: Right rear axle seal in reply to John from IL, 08-24-2002 14:55:48
First remove the wheel and hub assy. off the axle. Take the 4 bolts out of the metal dust cover and remover becareful not to damage the felt seal in it. Then take a rubber mallet or leather head hammer and bump the next cover off. Flip over and there is your seal to knock out. Part #UT459A. Of course be careful and block the tractor well and you might want to drain off a little of the oil out of it as well. you can get a seal for it at your local NAPA store. Good Luck
John
08-24-2002 19:23:49
 Re: Re: Right rear axle seal in reply to Kevin Moschenrose, 08-24-2002 19:11:59
Thanks Kevin, that`s exactly what I needed!!!! Great!!!!!
