Minneapolis Moline Tractors Discussion Forum
Re: g450 cotter pins near rear hydraulic drain plug
Mongo59
05-24-2020 21:54:04
Which place did you use to add new fluid to the hydraulics? If it was the large cap in the front/right of the seat you are ok. That is where you fill the hydraulics and check with the dipstick by the parking brake.
If you used the plugs under the tractor to drain the hydraulics, then those are for the gear oil in the trans-axle. Both of them. Those are filled by the small plug in the front/left of the shifter and checked by a weep hole back by the PTO shaft.
Did you change the filter? It is in the hydraulic line under the tractor in front of the right foot plate. Oh, and if you leave the large fill cap off when you start the tractor your hydraulic oil will come oozing up out of the reservoir. (Don't ask...)
