TRANS OIL
KEITH MORRIS
08-11-2002 16:20:22
Need to know what weight oil to use in a 67 JetStar 3 Ind. tractor has powersteering and hyd no 3 point.
Pete-mi
08-12-2002 21:03:26
 Re: TRANS OIL in reply to KEITH MORRIS, 08-11-2002 16:20:22
The trans uses 80-90w oil.You dont want to use hy-trans fluid in the M-M trans as it can cause the pto clutch to slip. The hyd system can use atf, 32,46,or 68 weight hyd fluid or hi-trans fluid.
KEITH MORRIS
08-13-2002 15:07:16
 Re: Re: TRANS OIL in reply to Pete-mi, 08-12-2002 21:03:26
thanks for the info this tractor rolled off of a truck and I am repairing it to use. Again Thanks
