Pulling with stock mm zb
peter hendricks
07-21-2002 11:54:31
can i compete with a stock mm zb at any tractor pull?? i need advice thanks millions
Mike
07-28-2002 11:00:13
 Re: pulling with stock mm zb in reply to peter hendrickson, 07-21-2002 11:54:31
We pull a ZA inb the 4500# class and do rather well. Run the rear tires at 8 psi and have the weights hanging on the rear of the tractor. good luck pulling
Joe Leising
07-21-2002 20:14:23
It depends on the rules, and how stock your ZB is. I pull mine and do OK, but we pull low gear stock RPM so I don't need huge HP. I am oversize with M&W's, but that is how it was farmed with. Send me an e-mail if you want more tips on setting it up.
Joe
Andy
07-22-2002 20:47:54
 Re: Re: pulling with stock mm zb in reply to Joe Leising, 07-21-2002 20:14:23
ZA's/ZB's can do very well in stock pulls. make a drawbar that's as high as allowed,(18"-20" high). I have pulling drawbar and a field work drawbar, it takes 3 minutes to switch. Make a wieght bracket to mount on the bell housing and find some suitcase weights. Check your rpms. We've had Z's that won't even run at factory specs.(1650 no load rpm's) if your not getting at least that grind a bit off the wieghts or send your governer to motec. fool around with your tire pressure, we have good luck around 10 psi. Do this and you should be able to run with any stock JD A or 77.
