White 2-150 loader size
toplesscamaro
07-17-2002 15:35:44
Loader size needed for this tractor or if it is even possible. This tractor any good?
One is available at an auction this weekend.
freddy
07-19-2002 19:27:41
 Re: White 2-150 loader size in reply to toplesscamaro, 07-17-2002 15:35:44
yes this is a good tractor to use for a loader. same as a 1355 MM. oliver rear end with a MM 585 diesel engine. Has a tough adjustable front end. watch out for the frame rails. White to increase steering power changed the front end from the G1350 to the G1355/2-150. They put two steering cylinders on it. thats the good idea! the bad idea was to isolate the after attach fitting away from the oil pan to the side frames. For ease of assembly they over sized the holes they drilled in the bottom of the c-frames. Thats where they break., through the mount holes. my advise is to plate the frame with 3/8 plate before you put the loader on . with normal use you will never have a problem .
