Minneapolis-moline corn sheller model d
Caroline Kjeset
06-30-2002 10:30:39
Does any one you how or why I could get information on a m.m. corn sheller model d.thank you for your help [email protected]
Kevin
07-07-2002 07:19:57
 Re: minneapolis-moline corn sheller model d in reply to Caroline Kjeseth, 06-30-2002 10:30:39
We happen to have a restored model D sheller that I recently found original found original manuals for.According to the book,there is an assembly that bolts to the blower shroud & has the driving sprocket below with an idler sprocket above the cylinder drive sprocket.The chain is fed around the middle gear in order to reverse rotation.If you need more information,drop me a line & I'll photocopy what you need & send it to you.
Caroline Kjeseth
07-07-2002 10:44:48
 Re: Re: minneapolis-moline corn sheller model d in reply to Kevin, 07-07-2002 07:19:57
Kevin Could you photocopy that information for me. Thank you so much for your help. Caroline [email protected]
Kevin Moschenrose
07-01-2002 07:46:02
I have a model "D" corn sheller that is operational. What do you need to know?
Caroline Kjeseth
07-06-2002 08:50:31
 Re: Re: minneapolis-moline corn sheller model d in reply to Kevin Moschenrose, 07-01-2002 07:46:02
We need any pictures and information how to hook up to a pto. Thank you [email protected]
Caroline Kjeseth
07-02-2002 16:56:12
We need to now how to make it work off a pto. Where can we get informatiom on how to do this Thank you [email protected]
Caroline Kjeseth
07-01-2002 09:23:34
information on how to work it and how to make it work off a pto. thank you Caroline [email protected]
Harold
06-30-2002 18:27:27
What kind of information do you want? We used to have one and shelled alot of corn with it. Harold
Caroline Kjeseth
07-08-2002 12:37:32
 Re: Re: minneapolis-moline corn sheller model d in reply to Harold, 06-30-2002 18:27:27
We would like ti know how to make it run off a pto. as we do not have a tractor with a belt pully . Can you help us with this. Thank you Caroline
Harold
07-09-2002 20:37:06
 Re: Re: Re: minneapolis-moline corn sheller model d in reply to Caroline Kjeseth, 07-08-2002 12:37:32
Is the sheller set up for belt drive now? If it is do you have a PTO kit for it? Where are you located? In some parts of the country there are still some around, and if you don't have a PTO kit you might find an old one to take off. We changed ours ovber from belt to PTO and it is not to hard to do. Let me know what you have and I'll go from there. Harold
