Rear engine seal
paul-p
06-12-2002 10:22:24
I recently completely restored a 1960 Jetstar.This year and model uses a felt rear seal,
which was replaced, and it fit well. it now weeps oil while running and drips out when standing.
Is this normal and I should get used to it, or is there something that can be done, short of splitting it and replacing the seal again, which did not work the first time anyhow?
Ryan
06-14-2002 04:01:57
 Re: Rear engine seal in reply to paul-p, 06-12-2002 10:22:24
Perhaps the felt seal just needs time to soak some oil in and swell a bit. How long has it been in there?
Ryan
JK
06-13-2002 13:27:30
If you use a lip type seal on the crankshaft designed for the felt seal, the seal will be damaged imediately due to the spiral cut in the seal surface of the crankshaft that causes the oil to be pumped back into the crankcase.
John
Kelvin
06-12-2002 21:05:36
I'm sure you thought of this, but did you replace the seal on the transmission input shaft? did you pre-lube the felt seal so it wouldn't scuff or burn on initial start up?
Paul-P
06-13-2002 09:45:39
 Re: Re: Rear engine seal in reply to Kelvin, 06-12-2002 21:05:36
Thanks Kelvin, every seal in the beast was replaced, and every bearing. I had oil on all wearing surfaces and even a little teflon assembly lube, it wasn't saturated but it saw some lube.
DLP
06-12-2002 11:03:00
To my understanding, a felt seal has to let some oil through to lubricate. If it doesn't, it will burn the felt out. When I rebuilt my ZTU I used a rubber lip seal front & rear. They are holding fine.
Ryan
06-14-2002 04:03:10
 Re: Re: Rear engine seal in reply to DLP, 06-12-2002 11:03:00
Glad to hear that the new style seals are holding up, I have to put the crank back in my ztu and it had the felt but I will be using the lipped seals as well. Good to hear.
Ryan
Paul-P
06-12-2002 11:39:04
MM went to lip seals in later model years.Ihave an old JD B with felt seals that seem to work better.
