Positive or negative ground
Darrell
04-27-2002 20:36:36
Just bought a 53 ZB. There was no battery in it and am not sure if this was a positive or negative ground.I do know that it is a 12 volt system as it is marked on the generator and starter. Can any one help me. Thank You.
Jim Parisot
05-02-2002 06:53:48
 Re: Positive or negative ground in reply to Darrell, 04-27-2002 20:36:36
Darrell,
You're getting a little bit of conflicting information, but let me side with those saying your system was originally a 12 volt positive ground. When you set it up it really doesn't matter which way you have it. Put the battery in and ground whichever terminal you wish (I suggest keeping with the positive ground)and before starting polarize the generator. You polarize by "flashing" the gen. terminal and bat. terminal on your voltage regulator. When you see the tiny spark that's all there is to it. Then, make sure that whichever post of the battery that is grounded has that terminal of the coil (+ or -) going to the distributor. If the ammeter reads backwards just switch the wires. Hope this helps.
Jim
Kelvin
04-29-2002 17:04:12
We've had a ZB on the place since it was new and it is positive ground.
Darrell
05-02-2002 21:05:16
 Re: Re: Positive or negative ground in reply to Kelvin, 04-29-2002 17:04:12
I checked voltage at the coil and it is 12 volts on the neg. side. So it must be positive ground.And yes all ZB's were 12 volts, that was one of the changes for that model. So thanks guys for all the help.
Mike (WA)
05-01-2002 08:28:24
My Oliver 550 diesel is factory 12 volt, positive ground- but the ZB would have been 6 volts originally, so if its 12 now, it was converted. Every conversion I've ever seen was negative ground. Also, look at the small wire from the distributor to the coil- then post whether that wire is hooked to the + or - post of the coil, and someone smarter than me will tell you which grounding you have.
BMG
05-01-2002 18:31:18
 Re: Re: Re: Positive or negative ground in reply to Mike (WA), 05-01-2002 08:28:24
Well Mike,
I have to correct you. All ZB's were 12 volt from the factory. ZT's and ZA's were 6 volt.
Brian
jason
04-28-2002 06:03:53
I have a 1954 zbe and it is set up as 12 volts and negative ground. i'm pretty sure all 12 volt systems are negative ground.
