Manifold
bill hillbrant
04-15-2002 19:08:58
have a g gasser with a bad manifold -have a lp manifold system that i could use-has anybody used a lp manifold on gas? thanks bill
JT
04-20-2002 10:12:23
 Re: manifold in reply to bill hillbrant, 04-15-2002 19:08:58
Bill
The tractor will run but you will experience a lot of problems with icing. The reason for this is that energy (heat) is required to turn any type of liquid into a vapor. LP tractors did this with the convertor (regulator) using the coolant to heat the fuel and the carb only received the fuel in the vapor form. Gas carbs do this at the venturi and use the exhaust to heat heat the intake.
Engine builders used different manifolds for LP because there was no need to warm the incoming fuel/air mixture and cooler air is more dense. More dense air means more oxygen which in turn means the potential for more power.
I know MM on the ZA at least used the same exhaust manifold with different intakes if you are just replacing the exhaust you may want to consult a parts book.
Pete-mi
04-15-2002 20:23:02
I should work well. If you live in one of the northern states you may need to add a plate over the center of the intake to the exhaust manifold. This will transfer some heat so the carb doesnt frost over.
reddog
04-15-2002 19:26:32
yes,tractor will run good maybe better
scott from down south
04-15-2002 20:16:15
 Re: Re: manifold in reply to reddog, 04-15-2002 19:26:32
One guy was on here the other day and he had LP manifolds on a gas tractor and it was freezing up.I have never experienced that problem here because we run LP. You can't keep 5 gallons of gasoline here overnite!
bill hillbrant
04-16-2002 18:59:04
 Re: Re: Re: manifold in reply to scott from down south, 04-15-2002 20:16:15
think i will try it-have to do a little southern enginering but believe it will work-will let you know how it does-thanks bill
