R starter
Ted
04-03-2002 18:50:21
The starter stays engaged after I release the start switch, would this be starter drive problem or possibly the seleniod on the starter? Thanks Ted
deadeye
04-05-2002 05:46:13
 Re: R starter in reply to Ted, 04-03-2002 18:50:21
Just a couple more things it may be. If it has been converted to 12 volt, it may be a weak bendix spring which will give you fits or could be the solenoid as you said. Or if you are in the process of changing it to 12 volt, it could be wired wrong. Good luck!! deadeye
Kelvin
04-04-2002 17:24:08
Just a thought. If your tractor has the small black starter push button, could be the pushbutton switch is sticking. I've seen that happen twice.
