U-302 rear hubs or 445 hubs
Turbine Dude
03-30-2002 19:17:19
I am looking for a pair of rear hubs for a u-302 to go on the standard bar type I believe it is a 2-3/4 inch axle 9 lug. If not i think a 445 hub is the same or simular, I have one that is broken and one that is about to break so i want to replace them both any help or leads would be greatly appreciated. Later T-D
J. Banet
04-07-2002 00:49:33
 Re: U-302 rear hubs or 445 hubs in reply to Turbine Dude, 03-30-2002 19:17:19
We use 150 lb. wts. from a IH-M. Their bolted on with threaded rod. Very easy to come by. First thing I'de do is fill the tires. Should weigh around 5600# with fluid. That should be plenty for what your doing.
justin
04-02-2002 15:08:01
Is it a utility tractor? What size tires or does it matter?
