Weak points on White 4-150
Phil T.
03-18-2002 17:44:49
Looking for a lighter duty 4wd tractor an it seems that White 4-150's are relatively cheap. What are the weak spots on this tractor. It has a 3208 Cat, can it be tuned for more power without breaking the driveline? Wanted for its rumored ability to straddle 4 30" rows.
Thanks,
phil
steve
03-21-2002 16:31:01
 Re: Weak points on White 4-150 in reply to Phil T., 03-18-2002 17:44:49
I have a white 4-210 never any problems for long time we did change engine for repair one as it has been worn out. there was no mayjor repairs on the tractor from time we buy it new.
hardscrabble
03-21-2002 18:23:12
 Re: Re: Weak points on White 4-150 in reply to steve, 03-21-2002 16:31:01
I think the 4-150 White had the same problem as the 2+2 IH's. They were oversold/overrated. If you knocked about 25 horses off the power rating , and thought of it as a 125 hp tractor, you had a very good machine.
David B
03-19-2002 09:53:10
Rough riding, Guys 100% right on this one
Jeremy
03-18-2002 21:04:42
We really liked the 4-150 we had, I'd say the only down fall the tracor had was the Cat engine which we never had any problems with while we owned it. Something you will also want to watch is the clutch make sure it holds along with the normal things you watch with any tractor. We had duals on front and rear. Really wish we would have kept that tractor and forgot that 7130 Magnum. Grandpa has a 4-210 and the 4-150 would run with it the Magnum is a differen't story the 4-150 would just run over the top of it and never think twice. Not as bad as the 8970 Gensis we demoed would that was a tractor. I guess we live and learn.
galen
03-18-2002 20:04:56
White 4- series had final and axle bearing problems when first came out had some modifications don't know if it cured it or not. Most of them I was around at the time unloaded pretty quick. I ran a 4-180 for some guys nights was a smooth running sucker. Don't care much for the cat throw aways myself. But everbody has different opions. If I remember correctly you weren't supposed to put duals on front axles or maybe was local dealer recommendation.
Guys
03-18-2002 19:58:36
The weak points start at the radiator and end at the draw bar..... Cheap tractor
Harrold Rhodes
03-21-2002 18:10:55
 Re: Re: Weak points on White 4-150 in reply to Guys, 03-18-2002 19:58:36
The 4-150 had lots of weaknesses but still better than the comparable John Deere.
Darren
03-21-2002 19:36:41
 Re: Re: Re: Weak points on White 4-150 in reply to Harrold Rhodes, 03-21-2002 18:10:55
Just curious, what is the comparable John Deere model?
Harrold Rhodes
03-22-2002 18:24:11
 Re: Re: Re: Re: Weak points on White 4-150 in reply to Darren, 03-21-2002 19:36:41
The 30 series FWD's
