Thermostat
Brian Williams
02-24-2002 16:54:30
Does a 1947 MM U with a KEF engine use a thermostat? If so where is it supposed to be located. Excuse my ignorance but I'm new to MM tractors.
Darrell
02-24-2002 21:04:44
 Re: Thermostat in reply to Brian Williams, 02-24-2002 16:54:30
It is in the radiator under the top housing that the hose goes on, at least that is where it should be if it has not been removed.
Kelvin
02-25-2002 12:44:59
 Re: Re: Thermostat in reply to Darrell, 02-24-2002 21:04:44
If you replace the thermostat, you'll need a hole in it if it doesn't have one already, because a small amount of water must circulate up to the radiator to heat the thermostat so it will open.
