Pulling jugs apart jet star3
greg m
02-22-2002 20:47:18
Trying to pull jugs apart on jet star 3. figure i would ask before continuing as i do not want to damage connecting pipe. need to replace gasket.
rebuilding engine, do these need to be replaced?
G. L. Perry
02-24-2002 22:05:13
 Re: pulling jugs apart jet star3 in reply to greg m, 02-22-2002 20:47:18
You do know both jugs have to come off together? Lots of times during OH guys will just put pistons/rods and jugs together on engine as a "set". If just doing gaskets, maybe this is too much work to remove rod ends and pull. Then you would have to open side of engine and all.
JK
02-23-2002 06:43:46
Greg,
It depends on the water in your area. In out area the water seems to eat the metal tubes through after a few years so I always remove them and check for pits. If they are pitted replace them and the o-rings, if not just replace the o-rings.
John
