Poor Valve Oiling on RZ Models
Galen Ishman
02-18-2002 14:55:12
I am going to rebuild the tob end of my MM ZB and was wondering if anyone has messed with retrofitting a better valve stem oiling system than the "Nails poked into the Tube method"
I had thought of fabricating a copper tube with small copper lines that could be aimed at each valve stem but was afraid that I might lose too much pressre in the rest of the system.
Any success stories out there on this problem???
Mike (MI)
02-25-2002 05:04:54
 Re: Poor Valve Oiling on RZ Models in reply to Galen Ishman, 02-18-2002 14:55:12
Galen,
Valves only require a "mist", or a drop of oil once in a while. If you squirt oil directly on them, the intake seals better be in excellent condition, or you will suck oil down the guides at an idle. A little oil is great, but too much will lead to other problems. If you do happen to get oil down the guides, it will "coke" on the back side of the valves. Good luck,
Mike
