V minnie-mo
hay
02-12-2002 10:13:04
wow, what a find!. i found a minnie-mo model "V" just sitting in the woods. talked to the owners and they want $300 for it. does NOT run and some of the engine parts are missing. i assume that this is a hercules engine? would parts still be available for this engine? i think it is a late 1940's or early 1950's tractor. also did this tractor have a 3 pt. hitch from the factory and hydraulics or was this an add-on. no pto shaft and i was wondering if one could be installed. any information on this model would be appreciated. this is the first small size minnie-mo i have ever seen.
Vince
02-15-2002 06:24:26
 Re: V minnie-mo in reply to hay, 02-12-2002 10:13:04
I have a B.F. Avery Model V. You have the same thing. Do a search of this site (all topics) for Avery and zxb-3 (hercules engine model) Lots of info, parts suppiers ex. Get an I&T manual (MM-201 covers Averys and almost all MM's)from www.intertecbooks.com (they are the publisher) or where ever you get your I&T's. They did have a Hydrolic lift option, funny thing on the (passanger) right side of frame. Nothing that we would recogze as a 3pt but did have a lift. Mine has a pto but no factory hydrolics. My grandfather added a car power steering pump, valves and a small hydrolic cylinder to power the lift. I haven't started to work on mine still trying to figure out what to do with only 15 hp.
hay
02-15-2002 07:15:55
 Re: Re: V minnie-mo in reply to Vince, 02-15-2002 06:24:26
thanks for the information.
