Rear wheel for a zau minneapolis- moline
eric miller
01-18-2002 09:09:17
I am searching for a rear wheel for a zau.Any help would be appreciated if you have one,or if you know where I could get one.Thanks.
topo molawa
03-14-2002 06:01:50
 Re: rear wheel for a zau minneapolis- moline in reply to eric miller, 01-18-2002 09:09:17
do u have any knowledge concerning pumping water into the rear wheel of a tracor?If yes why is water pumped into the wheel and what is used to carry out the function except using a hose pipe connected to a tap?
Chad Penny
01-18-2002 12:04:31
are you looking for just the rim?
I may have one
eric miler
01-18-2002 13:49:32
 Re: Re: rear wheel for a zau minneapolis- moline in reply to Chad Penny, 01-18-2002 12:04:31
Yes,I only need the rim.How much would you be asking for it?
walt f
02-03-2002 19:05:04
 Re: Re: Re: rear wheel for a zau minneapolis- moline in reply to eric miler, 01-18-2002 13:49:32
is the wheel a pressed steel wheel or a pressed steel rim on a cast iron hub? i think massey harris, john deere, oliver all used those same wheels and i.h. used those pressed steel wheels on their combines...
