Need Crankshaft
David H
01-13-2002 18:27:11
I am in need of a MM G crankshaft in good useable condition. If any one knows or has one I would appreciate the info. Thanks, David
Jeremy
01-14-2002 20:51:56
 Re: Need Crankshaft in reply to David H, 01-13-2002 18:27:11
Dave do you have an old one with a bad jurnal or just want one.
David H
01-15-2002 04:36:52
 Re: Re: Need Crankshaft in reply to Jeremy, 01-14-2002 20:51:56
Jeremy, I have a 54 UBE D that has a fresh rebuild on it and I was thinking about putting a G crank in it. I just thought if I found one I would pick it up if the rod nd mains are the same size. Thanks, david
Jeremy
01-15-2002 17:52:27
 Re: Re: Re: Need Crankshaft in reply to David H, 01-15-2002 04:36:52
I have a 403 crank I haven't checked any of the rod dia's to see if they are round or if they have been turned. I really don't want to sell it I have some Ideas for a build for a solid block U I have or maybe a five star. The U is the one I'm looking at really hard I'll keep the stroke 6" for the U I can't cut the tops of the pistions enough to offset grind it. If you had a G or some thing that had a bad throw that would trun down fine for the smaller U rods I may have traided you cranks.
The G crank has the same main dia's but the G rods dia's are smaller than the U diesel's and larger than the U non-diesels.
Jeremy
