ZB timing
Chad
01-13-2002 10:24:02
How do you time a ZB?
DMM602
01-18-2002 18:54:28
 Re: ZB timing in reply to Chad, 01-13-2002 10:24:02
Chad, I have timed a ZTU and think it is basicly the same.The question is,has your engine been apart or are you just wanting to tune it up and set the timing?If you are just setting the timing,there is a pointer inside the clutch housing(left side of the tractor just behind the engine is a square accesss hole for clutch adjustment).The flywheel is marked for top dead center.The ZTU has another mark for fireing no.1.The engine should be running at high idle and the pointer should line up with the fire mark with a timing light.If not turn the distributor until it lines up.Be very careful around the fan and the flywheel with the engine running.You will probably have to hook your timing light to a 12 volt battery.Hope this helps a little and I hope the ZB is like the ZTU.Good luck and be careful!!
