U oil pump trouble
Chuck M
12-29-2001 14:36:12
I started my U a couple days ago and no oil pressure. I dropped the oil pan and removed the oil pump and found that half of the teeth are gone from the oil pump. Is the cam wiped out too? Is the gear replacable?
Kelvin
12-29-2001 17:15:08
 Re: U oil pump trouble in reply to Chuck M, 12-29-2001 14:36:12
You might be able to see the gear on the camshaft by removing the governor and looking in through the hole. Or by looking up in the oil pump mounting hole. The gear on the camshaft is actually cut on the camshaft and is not replaceable except by replacing the camshaft.
Also, you need to determine what caused the pump to look up. Did a little water freeze in it?
Chuck M
12-29-2001 17:24:03
 Re: Re: U oil pump trouble in reply to Kelvin, 12-29-2001 17:15:08
yes I found some water present.
Chuck
12-30-2001 19:36:09
 Re: Re: Re: U oil pump trouble in reply to Chuck M, 12-29-2001 17:24:03
Thanks for tip Kelvin, looked from where the oil pump goes in. Not happy for what I saw.
Keith
01-06-2002 16:10:59
 Re: Re: Re: Re: U oil pump trouble in reply to Chuck, 12-30-2001 19:36:09
Let us know the outcome Chuck. Good luck.
